Need help.
Old Aug 14, 2018 | 03:36 AM
Storm Dutil's Avatar
Default Need help.
I have a 2004 Jeep. Check engine light came on so ran the code it needed a new solenoid pack so I installed it works fine. But now gear shifter is off I can go in to reverse in less I just pass it and then come back to it. Same with drive. I have to just pas any gear that I want to be in. I replaced the shift cable already.
Old Aug 14, 2018 | 04:38 AM
Canvas's Avatar
Veteran: Navy
Check to make sure the linkage/cable is adjusted. It may have gotten wonky when you swapped the solenoid or cable.
Old Aug 14, 2018 | 09:52 AM
I already adjusted the linkage at the shifter
