JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   The New Member Registry (https://www.jk-forum.com/forums/new-member-registry-21/)
-   -   Slip Indicator light (https://www.jk-forum.com/forums/new-member-registry-21/slip-indicator-light-286850/)
Bkdavila Sep 26, 2013 05:03 PM
Has any one had issues with there
Slip indicator light turning on. I have a 2012
Jk and it seems to turn on and off for no reason. It has even turned
On when just sitting at light. Any help would be appreciated.
lkinmond Sep 26, 2013 05:21 PM
Have you asked the dealer about it? Do you have a lift etc? It could be many things from alignment to clock spring to a finicky sensor - my guess would be the last one.
Bkdavila Sep 27, 2013 07:33 AM
Thanks, I have a 3.5 BDS lift kit, going to get the alignment done again and tires rotated, but I have a few friends that have been having the same issue of the light coming on randomly.
elmo4x4 Sep 27, 2013 06:15 PM
2012 JKUR. Mine would flash along with the "sway bar" light. The buzzer would "ding" all gages would zero and if you had the cruise set it would cancel your cruise. Airbag light came next. Took it to the dealer. Failed right front crash sensor and failed occupant restraint sensor... They had the crash sensor in stock so it was changed. No problems now besides airbag light still on. The occupant restraint sensor should turn off the air bag light according to the dealer but so far so good.
Robnasty Sep 27, 2013 06:21 PM
Mine has recently started doing this. No rhyme or reason. Some times it will do it every few seconds about 10x. And sometimes 1x an entire 20 min drive or not at all
© 2026 MH Sub I, LLC dba Internet Brands
