Hi from NZ
2010 JK 2-door manual 3.8
I have an intermittently flashing odometer (still works). No codes thrown. Mechanic thinks it is likely the vehicle speed sensor (#PA66 GF30).
I'm trying to source a replacement but haven't had any joy (MOPAR, ExtremeTerrain, Amazon,Rock Auto).
Can anyone suggest a good parts supplier to try?
cheers
hmmm, i kinda have a hard time thinking it's a speed sensor. typically when those have any issue whatsoever you are throwing a code or it is triggering an ABS light. I can't recall seeing much about flashing odometers over the years. I would tend to think it's more a computer issue, but that seems odd as well just being limited to that. I don't suppose you have the jscan app? i do see in live data under instrument cluster there are two PIDs related to the odometer, Odometer and Odometer-last chg data update. I'm guessing the first one just reflects the current mileage and the 2nd might just reflect the time since the last update. likely not helpful i guess. presume that it's tracking the mileage correctly and this is simply a display issue with the lights? what I do think would be interesting with those live data PIDs is if they were constant or if that data was intermittent as well. I guess that would shine light on if this is really just the display, or if this is actually the signal the cluster is getting from the computer.
