JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   The New Member Registry (https://www.jk-forum.com/forums/new-member-registry-21/)
-   -   Wheel spacers (https://www.jk-forum.com/forums/new-member-registry-21/wheel-spacers-352785/)
Bclev777 Jan 2, 2020 07:16 AM
Wheel spacers
I want wider tires on my jk Sahara but don’t want to spend the money on new rims are wheel spacers a good idea or should I just fork out the money on new rims?
resharp001 Jan 2, 2020 07:24 AM
There's nothing wrong with adapters, which is what almost everyone refers to as "spacers" but are technically different than spacers. Stick with a decent hub-centric one. If you do much work on the jeep yourself, it does get a little aggravating having another set of lugnuts to deal with anytime a brake rotor comes off, but they're a viable option to get more use out of your current wheels. If you are wheelin' hard at all, it's worth just getting a wheel with proper BS.
Bclev777 Jan 2, 2020 07:00 PM
would new rims and tires cost quite a bit more?
GeekyTechyCool Jan 2, 2020 08:21 PM
You're going to have to price out what you want and see. Generally speaking no, adapters/spacers are going to be a lot less money
I personly took my spacers off, I noticed a slight difference in how the Jeep handled but in the end, a different set of tires had the same/similar effect later on. I'm must not a fan of spacers, it's another part to worry about, it changes the geometry of the axle (same with running a wheel that isn't "factory spec"), and I'd rather deal with a little rubbing if need be.
Bclev777 Jan 3, 2020 09:52 PM
do you keep stock size tires and rims? What size tires and rims do you run?
GeekyTechyCool Jan 4, 2020 07:26 PM
Factory wheels and 35/10.50/R17 on a 2012 Rubicon Unlimited
Bclev777 Jan 5, 2020 12:39 PM
do you have any rubbing without spacers
GeekyTechyCool Jan 6, 2020 06:56 AM
No, check my build thread in my signature for more info.
© 2026 MH Sub I, LLC dba Internet Brands
