J-ust E-mpty E-very P-ocket
Old Apr 25, 2012 | 01:21 PM
Huck271's Avatar
Default J-ust E-mpty E-very P-ocket
You gotta pay to play the game but geeezzz..
I took the beast in to have the diffs checked and change the fluid and inspect everything from the MOAB trip. I had a leak coming from the rear diff. The diagnosis was that something had gotten wedged in the pinion seal and that was causing the leak (new seal $$), with the diffs off we discovered that my rear ring gear had chipped a tooth and there were stress fractures on the adjacent teeth so that has to be replaced. Not sure what happened here, I did everything right.. Hopping at Prarie City so hard I broke the drive shaft-Check, Peeling out with the new Hemi-Check, over flexing the rear in Moab and causing the rear driveshaft to hit the gas tank skid plates-check, I don't know what happened... (New ring/pinion/bearrings $$$) The front looked good, just needed new fluid (diff service $$).
I was hoping to get a roll cage this month, but I'll probably wait till next month assuming I don't break anything between now and then..
Huck
Old Apr 25, 2012 | 01:45 PM
ChopN's Avatar
If she's causing you too many problems I'll take it off your hands
Old Apr 25, 2012 | 02:57 PM
JKZinger's Avatar
I think the problem is the HEMI. We can swap motors at my place when you are ready!
Old Apr 25, 2012 | 03:30 PM
DanoPhelps's Avatar
Love the acronym
Old Apr 25, 2012 | 03:32 PM
BKGM Jeepers's Avatar
My jeep is pretty close to yours - AND I already have the roll cage in! I think a straight across swap makes sense so you can avoid those extra expenses!
Old Apr 25, 2012 | 08:33 PM
Huck271's Avatar
No, No... Its just like my kids ... deep down I don't mind paying for it.. Deep Deep Down.
Huck
