Thoughts on the new Rough Country 3.5 lift.
Old Nov 5, 2010 | 04:15 PM
  #171
WheelinWv's Avatar
I installed mine yesterday in my apartment parking lot with a basic tool set in the pouring rain as I live on the coast. Wasn't fun but the fender flares helped keep me dry. Took me 8 hours from start to driving by myself. I was able to pull the drag link off of the pitman arm with absolutely NO damage to the boot. I used my pitman arm puller on it. I shoved it up there between the crossmember and the radiator. I get a ratchet up there and cranked...BOOM it came right out no problem. Try that if you are feeling spry.
So far so good, I like the look and the ride. Adjusting the drag link collar was a challenge but doable -> sucks in the rain haha.
Cheers dudes.
Old Nov 5, 2010 | 05:05 PM
  #172
JKAbomb's Avatar
I should have figured!!! The dreaded DW came back. Im sure it has something to do with the trackbar. Previosly I installed a larger diameter bolt in the front upper track bar bracket due to egg shaping. Going to retorque all my bolts this weekend and may order front and rear adjustable. Damn you DW!!!!
Old Nov 5, 2010 | 06:30 PM
  #173
WheelinWv's Avatar
Thought I'd throw some pics at this thread.
This is my 2010 Jeep Wrangler Sport Mango Tango Auto 2dr
- 3.5" rough country lift with stock tires
VS.
Stock JK Unltmd on same stock tires
My JK with 3.5" RC lift with stock tires
VS.
2010 Rubicon 4" teraflex lift on 35x12.50x17
Cost of that 2010 Rubicon with 4" teraflex and 35s
My JK with 3.5" RC lift and stock tires
VS.
2011 JK with lift and 33s
VS.
And finally my JK parked amongst some stock jeeps.
Oh I almost forgot to add this:
Pic of clearance of front driveshaft *note I did not install the lower control arms OR the washers for the skid plate drop. I am going to go another route than what was included in RC's kit.
Hope this helps someone..
Old Nov 7, 2010 | 04:16 PM
  #174
sahara-07's Avatar
so did mine this weekend and everything went well .
did front and rear diff swap , rc 3.5 seri II lift and rc double steering damper .
hers some pic of the lift in progress :
Old Nov 7, 2010 | 04:26 PM
  #175
sahara-07's Avatar
only issue is my steering is like 1/4 of a turn off so my esp kick in at 50 klm and on the jack stand with the disconnects off even if ive chooped the crossemember and put on the shim the font diff is hitting the crossmember .
but love the ride it s awsome and the damper is super too !!
Old Nov 7, 2010 | 04:42 PM
  #176
A/C Guy's Avatar
Adjust your drag link to center your steering wheel.
Old Nov 7, 2010 | 04:58 PM
  #177
mkjeep's Avatar
Might wanna have that rear trackbar bracket welded/reinforced.
Old Nov 7, 2010 | 05:02 PM
  #178
jerseyjeepgurl's Avatar
Default second person helps with this
when we did this, I sat in the drivers seat while my husband adjusted the steering wheel. It also took a couple of test drives to get it pretty much 100% back to center. As soon as we got it pretty straight, all of the ESP problems went away. HOWEVER, be very careful on any clover leaf turns, as taking them with ANY amount of speed, makes that puppy go off, making it extremely difficult to take the turn. So, getting the steering wheel as straight as possible is imperative.
Old Nov 7, 2010 | 05:34 PM
  #179
sahara-07's Avatar
thanks for your advice
Old Nov 7, 2010 | 06:03 PM
  #180
Dozerdriver's Avatar
Default So...wich one would you get?
Should I go with the Teraflex 2.5 coil lift on my Unlimited or the RC 3.5 kit? Both seem to be decent kits. Not going to be doing any serious off roading but love the look of the JK with 35's. Drive shaft issues seem to be only if you are wheeling hard and sway bars disconnected?
