Who's using the Bushwacker Flat Fender Flares
I had the same fear you do. I dont like the wide open look of the fender cavity. One way around that is, yes a 40" tire...OR a good ratio. Get a bigger tire to fill the cavity and dont put a huge lift on your jeep. Stick with a 0-3in lift and a 35-38in tire. More than enough clearance for the tires and it will look good as well. Though first and Foremost, have a plan. What do plan on doing with your jeep?
i like the bushwackers best but worried about the mud spray with the top and doors off. i have a 2011 4dr rubi with 3 inch bds lift 33'' km2 and the jk micky thompsons so they stick out just a little past oe fenders and coat the sids with mud.... if anyone has the bushwackers and aftermarket wheels that stick out just a little do the flares cover enough to keep you from getting coated or will i have to keep the top and doors on? or do i need to go with a different brand..
