PRESS RELEASE: EVO MFG LCG Bolt-On Coilover Kits NOW AVAILABLE!!
Old Jun 15, 2012 | 07:40 AM
  #51
Blade's Avatar
Originally Posted by chris@offroadevolution
Control arms are not included. You will need at least lower front adjustables on a 4 door.
Awsome thanks.
Old Jun 15, 2012 | 07:41 AM
  #52
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Blade
I was just asking because the pictures only show the brakets and hardware. It was kinda misleading. What about control arms?
yeah, stuka pointed that out too and i agree, it is confusing.
Old Jun 15, 2012 | 07:47 AM
  #53
open_speed's Avatar
If you were starting with a totally blank slate JK 2 dr, what would you recommend to go with the coilover? I don't need everything to be top of the line. But besides the driveshafts, what should I add to the coilover order?
  #54
Blade's Avatar
the press release clearly states EVO LCG Bolt-On Coilover Kit w/EVO SPEC Coilovers. if you've ever priced out coilovers before, you would know this is really a killer deal for all that you get.
Definatly a great price. Coilovers themselves can run well over $600 each. I thought you were only getting the bracketry for that price. My mistake.
Old Jun 15, 2012 | 08:08 AM
  #55
wayoflife's Avatar
JK-Forum Founder
adjustable front lower control arms, front draglink flip/front track bar relocation, rear track bar relocation and rear adjustable upper control arms. that would be what i would recommend as a bare minimum.
Old Jun 15, 2012 | 08:21 AM
  #56
da wrangler's Avatar
I am anticipating this being one of the most active threads on the forum. When I woke up to see that they were up, I nearly jumped out of excitement! The Savin up will be worth it!!!!!!!!!!!! Thanks OFE
Old Jun 15, 2012 | 09:06 AM
  #57
chris@offroadevolution's Avatar
Sponsoring Vendor
As bare minimum lift kit combination on a 4 door JKU
EVO MFG front lower adjustable control arms $419.99
EVO MFG Draglink Flip $299.99
Plus the coilover kits. (The rear kit comes with the trackbar bracket)
We recommend front driveshafts on all JK's 2007 and UP
Rear driveshafts on all 2 doors 2007-up, along with rear upper adjustable control arms
Old Jun 15, 2012 | 09:14 AM
  #58
msells32's Avatar
My brain is spinning on this! Funding function fractions and amazing articulation angles are battling in my wallet!
Actually woke up checking the bank to see if a magical deposit had happened last night.
It didn't so this goes on the wish list!!
Old Jun 15, 2012 | 10:46 AM
  #59
open_speed's Avatar
So no rear upper adjustable control arms are necessary? Thanks!
Old Jun 15, 2012 | 10:48 AM
  #60
Sponsoring Vendor
Not on a 4 door
