Fire Engine Horn & On-Board Air
Old Feb 8, 2008 | 06:11 PM
  #21
USAF_GroundRat's Avatar
Originally Posted by Engine553
ZIP_TIES!
Dude, that's Pimp!
Video is priceless! Your right Trumpet off an engine is far better than a train horm IMHO
Well... I figured what the hell. Zip Ties kick ass! No-one will be looking under there but me (unless I am on my lid ). Then I go and post pics of it on the net! At least it will be easier to tear away if I get it hung up. It is actuall temporary until I get an aftermarket bumper and paint the horn black.
Old Feb 8, 2008 | 06:35 PM
  #22
mikeyfl's Avatar
where are the tank pics?
Old Feb 27, 2008 | 04:47 AM
  #23
Jacks or Better's Avatar
I mounted a pair of marine horns.. They sound decent, but I'm looking for something larger...
I mounted mine up in the front bumper.. It's protected them well from rock rash and grime... BUT... first time I went wheeling I filled 'em with water..
So, I'm looking for a new mount location, something a bit higher.
Old Feb 27, 2008 | 06:52 AM
  #24
RedneckJeep's Avatar
That right is funny, I don't care who ya are.
Old Feb 27, 2008 | 06:53 PM
  #25
mkjeep's Avatar
Just got me a 26in firetruck horn from a friend who works on them. He's gonna help with the install this weekend or next. Thanks for the write up, I'm stoked!
Old Feb 27, 2008 | 07:35 PM
  #26
Good luck brotha... keep us updated and PM me if you have questions!
Old Feb 29, 2008 | 08:38 AM
  #27
Voodoo's Avatar
Originally Posted by USAF_GroundRat
Yup! I will have to post pics of that. It is under the Jeep.
Tank Pics?
Old Feb 29, 2008 | 03:33 PM
  #28
Alright, here are more of the pictures that I promised.
I tapped into fuse number M-22 (Right Horn) which is on the fuse block under the hood, forward of the battery. I fed that to a switch, then to the relay. When you honk the horn the voltage engages the relay which then shunts 12volts to the solenoid to allow airflow to the horn. The switch is great so you can disable the air horn when you need to be more discrete. I forgot to see which fuse I was tapping into for the Ignition Hot feed to the Air Compressor. But you can judge from the pic (black wire) and check with a multimeter. This is also controlled by a switch that controls a relay. FYI, for those that do not know... you use a relay to prevent a large load across a switch.
Here are the Pics:
Follow the Blue wire for the horn:
Close-up:
Solenoid:
Relays:
Air Manifold:
Air Hose:
Air Tank (Temporary location):
Old Mar 27, 2008 | 07:59 AM
  #29
Fireguy0306's Avatar
It that a water can for a air tank?? Can't say your not resourceful.
Old Mar 27, 2008 | 04:34 PM
  #30
sixt7gt350's Avatar
That tank is frackin' awesome!
I remember my brother and cousin having some of those water/air extinguishers in high school. Smartaleck kids would spray squirt guns when you drove through their neighborhoods. The kids had no defense against a fire extinguisher retaliation.
I wonder if those are still around somewhere....
