Wobble, but not death wobble
I got a 07 2 dr rubicon with about 100,000 on it. About a month and a half ago I upgraded to some dick cepek fc 2s, 35x12.5x17. For the past couple weeks my jeep has become fond of wandering out of the lane when I hit a bump or pothole in the road. It's not death wobble cus I don't have to slow down to fix it and its not uncontrollable. Seems more like a serious case of bump steer, it's like the tires hit a bump and pull in one direction or the other. I can feel it through the steering wheel and it feels like there's some play somewhere up front. Idk if its just the weight of the tires or what but it seems to be something more than that. Any suggestions would be greatly appreciated, thanks.
I had same issues when I went to 35's it ended up being ball joints and wheel bearing had gone out. The bigger tires made the problem more noticeable. Just what happened to me.
No I haven't changed it yet but I have checked it to make sure that wasn't that problem. Mine seems to be holding up just fine still, I'm upgrading to the dual setup soon anyways though
Doyle_09,
Did you find the culprit yet? I'm having the SAME with my 2007 JK.. I swapped Draglink, tie rod and ends, swapped out the Trackbar bolts to larger ones, installed new steering stabilizer.. and replaced both upper & lower ball joints both sides. I thought I had defeated it as the problem went away for 3 months but has now returned again...
Doyle_09,
np. I saw post in the other thread just now as well. No PM yet, but will look for one. Typically for this issue, it's best to start a new thread just so it's easier for you to track and if someone else stumbles on it they may find it helpful....kinda like you're stumbling on old posts...cept those folks never followed up with their fix. Anyhow, the advice is always the same, but peoples' jeeps are all set up differently and they've addressed different things heading in to these issues, so it's good to know the base from which we are all starting to give advice.
