Rearview backup cams for OEM radios?
I'm starting to look into adding a rear view backup cam to my 2009 JKU's 730N radio since the J-Scan app seems to allow you to enable that functionality.
I'm interested in hearing feedback from anyone who has done similar for 430 or 730 radios.
Which cam did you get?
Where did you mount it?
How's the quality?
How did the wiring go and how's it look?
Any functional problems?
I would prefer to not mount the cam in the rear spare tire area, unless it doesn't involve removing the cam to take off the spare. So license frame mount or other areas? I also would prefer to not have any exposed wires showing as well.
How's the quality?
Harbor Freight doesn't offer anything?
I've got backup cameras in all but one of my vehicles and it's weird backing that thing up using mirrors alone. They are very nice on the trail with the Jeep. I don't have the factory head unit, but something along these lines would work:
https://www.quadratec.com/p/brand-mo...ep-wrangler-jk
I've got a plate mount on mine, in the middle of the tire, so I'd have to do some unwiring if I couldn't plug a tire and get it home. The system this one offers looks to be a better design as it sits behind the spare, so the wiring could remain intact in the event you needed to pop the spare off.
I don't know where else you'd be able to mount it that would give you the utility of having it up high and in the center, like you have with the spare mount.
Slightly off-topic but which OBD transmitter do you use? I just ordered the 16 dollar BT vgate (Icar 2 bluetooth 3) one from amazon and am really hoping for the best with it. So many of the models look the same
I prefer a centrally mounted camera so the view is accurate. I mounted ours on a piece of aluminum bolted to the spare tire carrier, sticking through the wheel slightly. cabling is out of sight as it is behind the spare. It does make getting the spare off and on a pain as you have to get the spokes lined up to clear the camera and lift it over the camera. I got a cheap camera from Amazon - https://www.amazon.com/gp/product/B07CPDNYGP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I'm sure others will do as well.
Wiring is not a big deal - route it alongside the existing tailgate wiring, removing a couple of panels in the back, then under the rug to the front, pull the radio and feed the wire up to it.
The view through the radio ('16 JKUR, which GPS radio that is) is great, looks stock. You do need a converter plug - here is the one I used. https://www.amazon.com/gp/product/B06XYSMB7N/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
For JScan, I use the VGate iCar2 bluetooth code reader from Amazon.
Does that cam work good at night? I noticed there's cams with infared LEDs around the lens and then the ones without like you have. I was thinking I likely needed one with the infared LEDs for better night viewing but I could be wrong.
I've been looking at similar style cams since I feel I may be able to mount a cam like that on the license plate frame.
I just ordered from Quadratech tonight. I've been wanting a back up camera for my 2016 Rubicon with Nav Radio since I bought it last year....
I'm calling it my Father's Day Present to myself.
I've watched several YouTube how-to videos and it appears pretty straight forward.
We recently did a front and rear camera set-up from BrandMotion that was a plug and play into the Mopar 430N AV unit.
They have quite a few different camera set-ups: https://www.northridge4x4.com/brand/brandmotion
Here's the install write-up from a couple weeks ago: Front and Rear Camera For Your JK
Camera mounting issue
I started to install a back up camera to on my 15 JKU. I have 35x12.5 tires. I use a spacer on my spare which allows the tire to just rub the bumper and clear the third brake light. The spacer changes the bolt pattern placement so the camera won’t show through the slot in the rim. I have black Willies rims. Guessing I’ll have to fabricate something? Anyone else have this issue?
