3.8 battery harness cuts
Hi my jeep was vandalized and they cut my battery harness all over. I'll attach a pic. The negative side was easy enough to fix but the positive side was cut in so many places the cables won't reach the terminal and I had to get rid of the fusible link to the alternator when cobbling it together.
I' trying to figure out my best course of action to fix this. I've found the entire harness for sale for about $150 brand new. Would like anyones opinion
<blockquote class="imgur-embed-pub" lang="en" data-id="a/TwusFGu"><a href="//imgur.com/TwusFGu"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
<blockquote class="imgur-embed-pub" lang="en" data-id="a/f6nG0R6"><a href="//imgur.com/f6nG0R6"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
[QUOTE=Almost Heaven;4342611]Hi my jeep was vandalized and they cut my battery harness all over. I'll attach a pic. The negative side was easy enough to fix but the positive side was cut in so many places the cables won't reach the terminal and I had to get rid of the fusible link to the alternator when cobbling it together.
Any idea behind the vandalization? I'd suggest whatever you buy comes with parking in a better neighborhood or stop messing around with the wrong chick.
Factory harness would be my first choice but I purchased a used headlight harness and merged it with my current harness in order to diagnose a much cheaper issue. You may be able to buy used and do proper gauge splices in order to fix what is broken without replacing that whole sub section. Figure out why it was vandalized before you fix it though otherwise you'll be right back here in 30 days.
Rednroll (05-23-2019)
Do you have squirrels running around your neighborhood? The red wires look an awful lot like the damage that was done to mine when a mama squirrel decided to build a nest behind the battery. The blue looks like a cleaner cut though, which is odd.
If you find that it is rodents, take care of them before you replace the wires. They chewed into the battery terminals and the edges of the battery itself on mine before I finally got them to stop..
Personally, if I was having to do this. I would look into thicker replacement wires. The JK can definitely benefit from some thicker wires when it comes to known power and grounding starter related problems. Instead of paying $150 for the same adequate wires, you could likely for a lower cost upgrade the diameter of those wires in the process and benefit with an upgrade.
I used this stuff to wire my winch. I bet it would work really well for battery cable and at 2AWG would be a huge upgrade over that factory 8AWG stuff but I'm sure there's other options.
https://www.harborfreight.com/6-ft-i...awg-63747.html
