Preventative maintenance recommendations for 2007 JK
I bought a 2007 JK (manual) with 144K miles. It runs great.
I changed all fluids and calipers pads and rotors, plugs and wires.
Planning to do a few longer trips this summer.
What else should I look into in terms of preventative maintenance?
Thanks
Jack
Thanks
Jack
By "all fluids" I presume you've included transfer case and gear oil for both axles. Inspecting steering components is always a good idea. TB, DL, and TR joints along with BJs. Does the jeep have factory or aftermarket drive shafts? If they are aftermarket double cardan shafts, most people overlook greasing the centering joint on the DC end....both because you don't really see the zerk and also cuz you have to drop the shaft to access it and most put it off.
The only other thing that comes to mind is having the battery capacity checked using the type of tester that uses a large current pulse and reads out in CCA (cold cranking amps). If a new battery is in your future, check out this test of an Odyssey.
Missed that one when you originally posted. Time for me to jump in and revive some discussion.
Mr.T (06-01-2019)
At 144 I would just change the starter anyway. I went with a new AC Delco Professional since the Mopar ones are hard to track down these days. It's 2 electrical wires and 2 bolts. Takes about an hour to do properly.
Water pump is up to you along with radiator. When I got to 140k I did the radiator. I should have done the water pump then also since I am about to do it this weekend. Upper and lower hoses for sure since its less than $20 and I would use the constant pressure hose clamps. Belt is only $15 so might as well if it looks original. PCV valve, Diff Fluids, Trans Fluid and filter, Coolant Flush, Brake Fluid flush are a few other things that come to mind. All really depends on time and budget. Buying it used you never know how the past owner treated it. All of that and you are still under $100 excluding a new radiator which is about $200.
I buy my stuff from quadratec and rock auto. They also price match each other.
