Vibration From Rear End?
I've been having a vibration that seems to come from the rear. It can happen at any speed but stops once I step off the gas pedal. When it occurs it can vibrate for a few seconds or longer. Took the rear drive shaft off and had the joints looked at. No cracks or wearing inside and they were full of grease. Tires are rotated on a normal basis. Wondering what else it could be if not in the drive shaft. Has anyone experienced this kind of issue?
Out of curiosity, did you take it for a spin while the rear DS was off?
I did not. Maybe I should add that my front drive shaft, where it meets the transfer case, has a torn boot. However, I wouldn't think that would affect the driving except when in 4 wheel drive. As a reminder, the vibration stops once I step off the throttle.
So, I wouldn't 100% write off the front shaft either. If the boot on the R-Zeppa joint at the transfer case is torn, it is on its way out, and should be replaced soon.
Happy Jeeping!
Sounds good. The front drive shaft will get fixed soon, just not soon enough. It's a place to start though and needs to be fixed regardless. Thanks for the help!
If you can't fix the front DS right away, I'd at least pull it off for the time being and go without. Dry CV joints don't tend to get better with time.
I had the front drive shaft repaired and still had the vibration while it was off. This is getting pretty tricky to diagnose. Hate to buy a whole new drive shaft but with 135k miles on the Jeep maybe it's a good idea? I'd sure like to get another 100k out of the Jeep.
