Ambient Air Sensor and Front Turn Signal Not Working
I need some help...I have searched and read many threads but can't find anything on the problem I am encountering.
I have a 2018 JKU with about 50K miles on it. Everything was fine. Let the vehicle sit for about a week and went to drive it. It threw code P0073 and the front right turn signal did not work. I've swapped the ambient air sensor with a new one, swapped turn signal bulbs, checked fuses, looked for wire damage, disconnected the battery, all with no success.
I am completely baffled. Any suggestions?
Put the battery on a charger to make sure it is fully charged and check all the fuses.
Most likely cause, rodents chewed some wires while it was sitting.
Check this thread. Rodents chewed wires near TIPM. If you haven't checked under the TIPM, it may be a good area to check.
https://www.jk-forum.com/forums/stoc...issues-349070/
