JK ABS Brake Computer
Anyone else running into trouble sourcing a replacement antilock brake system module? Google searching seems to indicate this is becoming a more common issue. Mopar has the part discontinued (2013 JKU / 68145835AE). I spoke with the parts department at a local Jeep dealer and learned the new part is 68145835E, however, that part won't be available till late May at the earliest. The new part is not listed at all on Mopar's website. It also seems the new part will be significantly more expensive with the dealership quoting approx $950.
Mopar changes the suffix on parts when the application carries over to a newer yr and when that part has had a engineering change. The Dealer parts dept could perform a supercession search forward and backward and then do a locate which will check dealerships parts inventories for that specific part number .. if found be sure to get the name phone number and address .. YOU make the call if you want to buy.
