Newbie here…swapping wheels and tires
I have a 2016 JK with 225/75/16. I just bought some 17” rims and not sure what tire size I should get.
No mods…yet and no lift.
Will 265/70/17:
rub?
need better suspension for the added weight?
make Jeep a bit taller?
Appreciate any help/info you can share.
Will 265/70/17:
rub?
You're good. use this to compare tire sizing https://www.calculator.net/tire-size-calculator.html. The key factor will be wheel back spacing and rim width.. The tire sizes you posted and considering. The 17 is 2.3" taller and 1.5" wider. The stock tire for a 2016 Sport S Wrangler was 255/75r17 which is a 31 inch tall tire .. 10 inch wide.. IMO..based on this you should be OK with the 265/70r17
appreciate your help,
