Universal ABS Sanner
I’m looking for suggestions on a scanner for diagnosing the ABS components.
I would prefere a universal sanner for use on muliple Makes and Models (Jeep & Ford)
Please only respond if you own and have used an ABS capable scanner.
jscan app with an obdII wireless dongle....you can get the dongle for $20-30 (which will work with a variety of apps, Forscan for most ford(or related), OBD Fusion has the GMstuff, etc)
Jscan is VIN locked so each vin will run you about $20...does everything the dealer can do afaik...
This is the adapter I use with my jeep https://www.amazon.com/Vgate-Bluetoo.../dp/B06XGB4873 there are other cheaper and more expensive options, if you look at the jscan page (https://jscan.net/supported-and-not-...-obd-adapters/)
vjsimone (05-10-2024)
