please help
OK, i have 2012 jk 3.6. i have replaced so many parts. but....here we go again. my starter died, killed my battery...so I replaced them both, drove and sounded amazing then......next morning i got p0522 code on jscan, and the cel only comes on when it gets to normal operating temp. the oil cooler and sensors are mopar, 2 months old. i know its the right oil, i checked the oil level, good. but i broke it down and thought the oil cooler was leaking again because its the code i got when it leaked. but i cant see any leaks from the oil cooler. i did find a small leak from the passenger side valve cover but its small, it might be from the pcv valve hose, (i replaced it when i did the oil cooler), maybe knocked the hose loose when putting in new battery???? but either way...it wasnt there before. i dont know how to check the voltage or anything on the sensor. or how to do the piv for oil pressure on jscan and dont want to keep throwing parts at it if its not the problem. any help would be much appreciated, life is hard right now, and i kinda need a hand up. thank you
