View Full Version : JK Wheels and Tires
- Rpm with 35's? Automatic
- Buy 3 Tires Get the 4th for $1*
- Beadlocks, 17x10, 5x5 bolt circle, 4.5 backspace,
- Need Tuner Advice
- What is this part and can I buy it anywhere?
- Picked up some new wheels
- Hard landing after potholes and speed bumps; missing front bump stops
- JKU tire question
- Goodyear Boulder MT
- Best ET for 33 tires?
- New Shoes for SeeMore
- New shoes goin on my JKU
- Beadlocks
- Alignment help.
- Gladiator Takeoffs on a JK TMPS issue
- Spyderlock Bolt Replacement
- Slow leak in tire
- What width spacer for 35’s w/stock wheels
- what tires?
- Clueless! Need help with upgrade info
- Wheel Spacers or bad idea?
- 42s vs 40s
- Changing tire size
- tires brand Opinions.
- Jeep Sahara slight wobble, need help
- Proper air pressure for oversize tires for street use
- KENDA KLEVER M/T2
- BFGoodrich K03's
- 35” on Stock JK Rubicon?
- Need tire help. New to jeep community
- New to me 2014 jeep rubicon built
- 33s bouncing almost wobble
- biggest tires for stock JK sport???
- New tires
- New Tire Suggestions - First time buying Jeep tires
- Tire Wheel Size Combo?
- All Original
- To run beadlocks or not to run beadlocks
- Wrangler JK Wheels and tires
- How much should it cost to replace rear wheel bearings on 2014 JK Unlimited
- Advice on affordable shock upgrade
- Replaced bad RF TPMS, Now RR is not responding
- Not really about tire but still related to tire.
- Outsdie fenders?
- Tire Help
- Need Advice for Tire Upgrade on JKU
- 35x10.5x17 Kenda Klever RT
- Tire size upgrade
- Newbie here…swapping wheels and tires
- Suspension 2015 JKU
- bigger tires - ESP on or off?
- Wheel Sale- Buy 5 and Save
- Are new duratracs really improved?
- Your Guide to JK Wheels and Tires
- Free Lugs & Sensors with Wheel Purchase
- Wheel and Tire Packages for Jeep JK
- Tire and Wheel Set Recommendation
- Aftermarket wheels - lug nuts too long?
- thought I understood backspace and offset...and then this
- 2018 Jeep Wrangler JK Tires
- Tire Recommendations
- Fitment Question
- Question
- 2011 JK with Stock 17" Rims
- New wheels and tires
- Wheel and tire specs, etc.
- Lug nuts
- What’s new for 35s?
- Odd click coming from rear end
- TPMS adjustment?
- shock absorbers rugged ridge ORV
- Spare Tire Carrier
- What contributes to cupping?
- Time for new tires
- Sell my Jeep?
- Anyone running Radar rt's 35's Thoughts ?
- Lift and tire sizes
- 35x12.50 tire weight between 18in wheels vs 17in wheels
- Aev procal doesnt have toggle switches?
- Tire widths
- Lift / tires / wheels / spacers
- Max Load on JK 18" Stock Wheels
- JL “Xtreme Recon” Fender Flares on JK
- Help with rim selection
- Dealer Coolant Flush Question
- Wheels and tires advice
- Jeep emblem on JL Wheels?
- Wheels for my stock 07 JK X
- Black Rhino Wheels
- Buying new wheels
- 2017 Rubicon tire popping noise?
- Pretty new need help picking tires possibly lift
- Leveling kit and tire size help
- Tires
- Rolling Mass of tires
- JKU Lifter Tick
- Wheel confirmation/info ?
- Fit 35in tires with 2022 Gladiator Rubicon wheels?
- Bead lock rim width question
- Lift and tires
- JL Sahara Wheels on JK Sport
- TPMS Valve stem
- How to determine wheel spacer size
- Regear or alignment first?
- Stock Rubicon wheel question
- In 2023 I resolve To Jeep with Metalcloak
- Does 2.5” lift need new shocks?
- Wheels 4.50bs
- Need tires, but have to wait on my lift.
- Basic Tire Help
- 33 inch tires on a stock Wrangler 2 door
- Dana 30, 44, 60
- Mounting a spare tire on a 2016 JK with an aftermarket backup camera
- Help Determining Offset
- Lift Height For 35’s
- What make / mfg wheels are these ?
- Mickey Thompson Baja Boss M/T
- New tires
- Free jk sport rims in central nc.
- TPM Valve Stems
- Tires
- Tires for Towing
- Coopers AT3 XLT vs Falken Open Range
- Chuck Mates -- faster, easier airing down
- Nitto vs BFGs
- Milestar Patagonia m/t tire pressure
- Upgrading Tyres on stock JKU sport 2017 18"
- Upgrading tires and wheels
- Changing from aftermarket wheels/tires on 2012JKU to Stock JL Rubi wheels/tires
- Do I need bigger rims
- mix and match rims
- jeep jk tire carrier Oem question
- Spidertrax wheel spacers part number identification
- Wheels/Tire change on stock JKU
- steel wheel interchange
- Updated List of 15" Wheels?
- Drag link interference question
- 2014 Rubicon factory wheel size
- Fab tech 3in lift kit
- Buying Wheel Take Offs
- Wheels and Tire Sizing
- 37s with a Beefed up D30?
- Vibration after regear
- Do you need spacers with a lift?
- interchange wheels from other jeep models
- 3.5" Lift Getting Installed - What size wheels should I aim for?
- 5.2" Backspace, Leveling Kit/33s
- Cooper STT Pro, ST Maxx, Toyo…
- Lets see your JK unlimited with 2 1/2" lift and 33's
- 37” sway
- What size wheels and tires?
- Need help with alignment
- wheel size
- 2010 Unlimited Sport - NEED Tires
- Tire options?
- Steering issues
- JK 2012 wrangler.
- Bump steer issues
- Pro comp series 97
- Wheels/tires and suspension/gears
- TPMS Help, Please.
- Price help
- Backspacing and TeraFlex Lift Kit
- Pics of wheels other than black or dark grey!
- Tires
- Inevitable Tire/Lift Question
- 35 vs 33
- Your tires 10 ply????
- Vision Nemesis Simulated Beadlocks
- Wheel/Tire Help + Lift advice
- Wheel spacers or lift?
- 295/70/r17
- New JK, tiny tires
- Has anybody seen my wheel?
- Up and down travel
- ID these wheels please
- Shaking in steering after going to 35s
- Flashcal stopped working
- TPMS on a JKU with bigger tires
- Wheel size for minimum Stickout
- 35 Nittos / Arsenal Pair
- Tires for daily commute
- LONG ISLAND…where to get tires mounted/balanced
- ABS, Hill Decent Control, and Traction Control Light
- NITTO Recon Grappler A/T Reviewed!
- Cupping tires
- Do I need a driveshaft?
- Rubicon wheels & tires on JK Sport?
- 2021 Rubicom Wheels and Tires on a 2017 2D JK
- Looking to put larger tires on my JK
- Opinions please
- Looking for Tire/Wheel to replace stolen one
- Tire stuff
- Jeep Newbie tire/wheel advice
- Do you HAVE to regear when going to larger tires, 35s?
- Wheel Up grade
- Need help w new bump stops
- Please assist
- After market wheels help
- 285 70R17 with Teraflex 1.5” leveling kit on JKU...
- Tires for lifted JK
- Tire Carriers
- Best Tires for Towing?
- Anybody running Toyo Open Country AT3?
- 1.75" Lift, Q: What to replace?
- Wheel identification
- Quick Lift Question + Build Path
- 2013 Rubicon Unlimited Tire downsize
- Wheel/Tire/Lift Recommendations Please
- **Need help**Trying to sell some friggin wheels and tires on here
- New and need guidance
- Abs light and pull on right wheel when start but goes away
- 35s on full stock jku
- Wheel recommendations for '13 JKU Sahara
- P or LT
- Can’t find in search, what’s tallest size tire for 2013 Sahara JKU stock 18s?
- Questions on the right tire size for new purchase.
- Spare rotation?
- Tryin not to be a DA
- Nub Needs Some Help with JL to JK Wheel Install (Specifically Lug Nuts)
- Can i fit a 315/75r16 tire on my stock 17x7.5 wheels?
- Great off road tires, stock wheels, stock size?
- 33", 34" on stock wheels. NoOb. (Couldn't find the right answer anywhere).
- Discount tire???
- Tire and Wheel help
- Teraflex Nomad Wheel
- Best wheels / tires for Trans-America Trail (TAT)?
- 245 or 255
- Improving ride comfort
- Balancing beads?
- 2021 Rubicon Wheels/Tires
- JK Wrangler in snow
- Rocktrix RT105 - 4.5" BS or 5.5" BS?
- Jl to JK TPMS
- Red Aluminum Wheels
- Fender law
- Lifting my 2017 2 Door! Need some help!
- Jeep modification plans
- Bfg ko2 37x12.50r17 or cooper stt pro 37x12.50r17
- Tire size / weight chart
- Fit Gladiator Mojave Wheels and Tires on a JK?
- Euro Wheels
- Rugged Ridge XHD failure, bent swivel pin
- What size are these?
- 37's on stock 2010 JK
- TPMS Sensors for a 2010 JKU Sahara?
