After Market Brake pads
Old Sep 8, 2009 | 02:01 PM
Rubicon_Fan's Avatar
Default After Market Brake pads
Its time to change my brakes.. Im only sitting at 43000 kms.. and they are gone! Tire shop says its the weight of my wheels and tires..
Anyways.. Im thinking of putting an after market brake pads and was wondering if anybody done that? And experience after that?
Im thinking Akebono ceramic brake pads.. Anybody have done that?
Any info will be appreciated.. Thanks..
Old Sep 8, 2009 | 02:06 PM
JdTms11's Avatar
changed mine back at 20k, ill probably have to change them again by the winter, i will have put 30k on since the last change, when i do i think im going to give the EBC pads and rotors a try.
Old Sep 8, 2009 | 04:44 PM
nangulator's Avatar
I just replaced my stock rear pads at 15k, I have talked to others that have worn out rear pads as early as 11k, I used Qualtran brakes, we stock them at work they are long lasting and usually noise free, much better than napa,autozone or pep boys crap.
Old Sep 8, 2009 | 06:09 PM
Gcollura's Avatar
Go with Hawk brake pads easy to do and last a long time. Not much dust either. I put them on my F250 also and have worked great there two. Very easy to do.
Old Sep 8, 2009 | 08:31 PM
CDavisJK's Avatar
Go with Hawk HPS (HB569.650) for the JK. These are great performance pads which will help if you have bumpers, skid plates, bigger tires, etc. If you just want a stock-like pad, the Akebonos are not bad.
Old Sep 8, 2009 | 08:52 PM
lv jk's Avatar
***erator
Default Hawk
I have heard a lot of good things about the Hawk pads I would give them a shot.
Old Sep 9, 2009 | 04:37 AM
JPop's Avatar
If you're pretty happy with the way your Jeep stops now and want some additional wear from brake pads the Hawks or EBC Green stuff would be a great replacement pad. If you have an extra heavy rig, and want more braking strength, EBC Yellow stuff.
Old Sep 9, 2009 | 05:32 AM
JeepDawg's Avatar
For the guys that are promoting the Hawks, which ones, the HPS, LTS or Performance Ceramics? I wouldn't mind a little more stopping power, but I specifically want LESS SQUEALING. I hate brake squeal.....
Old Sep 9, 2009 | 05:38 AM
JPop's Avatar
Bring on the brake squeal if it helps me stop faster and not squish Bambi or the idiot that made the left hand turn in front of me. If you don't want brakes that make some noise, stay away from the EBC yellow stuff.
Old Sep 9, 2009 | 05:46 AM
Gcollura's Avatar
Go with teh Hawk HPS, as long as you grease the back of the pad you should not have any squeal. FYI the brake pads come with the grease.
