4" Rough Country Suspension Lift... Help!
Right now i'm running with 32" goodyear wrangler tires and i want to install the 4" rough country suspension lift.
It comes with: Front and rear coil springs, trac bar bracket, pitman arm, front sway-bar links, rear trac bar bracket, brake line brackets, cam bolts, and (4) Performance 2.2 series shock absorbers.
My question is do what else do i need to buy in order to make sure my jeep still runs smoothly down the road and parts on my jeep won't break. For example do i need adjustable control arms or can i do without and be fine with just the kit as is??
I'll also be purchasing the rc dual stabilizer if that helps in any way. I'm all new to this so any advice on helping me build my jeep would be awesome!
Look for the other RC lift threads from the last week or two. Lots of good opinions and advice.
As MKjeep said, definitely look into some front control arms. (or at least do a search on those cam bolts so you know the pro's/con's)
Also look at the feedback concerning the trackbar brackets. If you don't go to adjustables, you might want to strengthen them.
It may not be an issue with 32's, but if you decide to go to a taller tire, some more bumpstop might be in order. The integrated shock bumpstop will help with downtravel, but I don't believe it will keep the tires off the fenders going up. (may not be an issue anyway if you do not disconnect?)
Once the lift is installed, flex it before you get out on the trail and check the brake lines. (with 4" of lift, I found that I needed extended lines & relo brackets)
Are you doing the install yourself?
http://project-jk.com/jeep-jk-write-...ation-write-up
If so, you'll need this also:
http://project-jk.com/jeep-jk-write-...-end-alignment
well if i upgrade up to the next lift set that is 4" for a couple hundred bucks it comes complete with control arms but they arent adjustable.. is that ok or should i be looking for lift sets with adjustable ones?
If you plan to keep that jeep a while get some adj. arms. suspension height may change as your needs change, wouldn't it be nice to adjust your caster and pinion angle? Those arms are a one-size-fits-all deal. I think a 2 door stock x with a soft top weighs a lot less than a 4 door with skids, bumpers, winch, armor, rack, hard top, etc. I bet there is at least an inch difference between the two. If I was you, I would get at least adj. front lowers and rear uppers.
I see you're running stock wheels. You'll need 1.5" Spacers if you run the 4" RC Suspension lift... or aftermarket wheels with 4.5" BS or better. And like others have already mentioned, Adj. LCA and Adj. Trackbars are good to have, but not necessary right away. They're next on my list of mods
