4in lift tire size recommendations
Old Sep 10, 2009 | 01:22 PM
rnuckols's Avatar
Default 4in lift tire size recommendations
I am getting ready to have a four inch lift installed next week and I will be getting new tires and wheels in about 2 weeks. I have a 4 door Sahara with an automatic and 3.73 rears. I would like to stay away from regearing. I am leaning towards 33s, but if I could get away with 35s and a programmer I would go that route. Any suggestions?
Old Sep 10, 2009 | 01:25 PM
bigbluejk's Avatar
man, 4in lift is tall for 33s. but 3.73s are gonna suck with that auto and 35s or bigger. Have you already bought the 4" kit? or can you get more like 2-2.5" kit and 33s. To me that combo looks good on a 2 door. I had 4.10s and 33s and it drove ok, I went to 35s and it drove like poop. Then I regeared to 5.13s and life is good. I used a 2" lift when I had 33s and now 35s on a 3" kit.
Old Sep 10, 2009 | 01:31 PM
EyeDoc's Avatar
Well if you need more research these may help:
SHOW YOUR 33'S link:
https://www.jk-forum.com/forums/show...ht=show+33%27s
SHOW YOUR 35's link:
https://www.jk-forum.com/forums/show...ht=show+35%27s
Bigbluejk is right on with the regearing advice especially with the 3:73 /auto combination you have. I just asked a similar question the other day and in the end decided on the 35's and the superchips at first and then save for the regear. I have the 4:10 / auto btw. My thread was here:
https://www.jk-forum.com/forums/modified-jk-tech-2/hey-daily-drivers-if-%24%24%24-were-no-object-would-you-go-33s-35s-100403/
Old Sep 10, 2009 | 01:33 PM
hyatt147's Avatar
Im running a 4" and 35s and it looks good but i could go with 37's easy.... Idk if 33's would really work out well with it. I think 35's will be the way to go
Old Sep 10, 2009 | 01:39 PM
rnuckols's Avatar
I've order the Rancho 4" sport suspension lift. If I went with 35s and got a programmer could it still be my daily driver comfortably or am I going to hate it without regearing?
Old Sep 10, 2009 | 01:47 PM
bigbluejk's Avatar
hard to say. everyone is different. IMO that is a lot of strain on the tranny, and you will no longer have OD. If it was me, I would go aheazd and do it, but start saving for a gear swap.
Old Sep 10, 2009 | 01:53 PM
opdsgt's Avatar
I think you will hate yourself running 35s with an auto and 3.73s. Zero torque, zero real world performance under load, inability to pull grades or pass, etc.
Old Sep 10, 2009 | 01:58 PM
JKRockStomper's Avatar
Your Jeep might look like this:
if you went with a 4" lift and 33s.
I would go with a 2.5" spring lift and the 33s.
Old Sep 10, 2009 | 02:11 PM
def9112's Avatar
Teraflex 4" lift = 37" tires for me
37"
Old Sep 10, 2009 | 02:33 PM
UCLA JK Rida''s Avatar
I have 35s and 4.10s with the Hypertech flashed ECU...it's not atrocious, but I definitely want some more power. If you don't mind a little throttle lag...go with the 35s and a slightly calmer tread than traditional mudders for lower rolling resistance.
Russ D.
