3" Lift
Old Sep 11, 2009 | 11:48 AM
Cerunnos's Avatar
Default 3" Lift
What is the best 3" lift kit to go with? Looking for a complete kit
Old Sep 11, 2009 | 01:12 PM
nthinuf's Avatar
Are you looking for a lift that 'says' 3 inches but actually gives quite a bit more, or a lift that actually 'gives' 3 inches? And since there are varying levels and opinons on what 'complete' is, what is your definition...
Old Sep 11, 2009 | 01:15 PM
TeraFlex's Avatar
Sponsoring Manufacturer
What size of tires do you want to run? Let's start from there.
Old Sep 11, 2009 | 02:07 PM
Cerunnos's Avatar
35s havent decided on width 17x8.5 rims with 5 on back spacing. Dick Cepek torque rims
Old Sep 11, 2009 | 02:11 PM
rubican!'s Avatar
2 door or 4 door caus ei think or at least ive heard the teraflex 2.5 coil yeilds 3 exactly. And i have found that at or under 3 inch's you dont need alot of the junk like new drive shafts etc.
Old Sep 11, 2009 | 02:13 PM
bigbluejk's Avatar
teraflex 3" kit with 35" mud grapplers:
Old Sep 11, 2009 | 02:15 PM
Cerunnos's Avatar
I have a 4 door wrangler
Old Sep 11, 2009 | 02:16 PM
JKRockStomper's Avatar
3" Teraflex w/ BFGoodrich KO 315/70R17
Old Sep 11, 2009 | 02:22 PM
Cerunnos's Avatar
would the 3" teraflex have everything i need. Would it be advised to get new drive shafts?
Old Sep 11, 2009 | 02:29 PM
TeraFlex's Avatar
Depends on which 3" kit you get. Download the 2009 catalog from my sig line. Look on page 9 for 3" kits and page 10 for 2.5" kits. You will either need to modify the crossmember or replace the front driveshaft with any lift kit in this range. Run the stock driveshafts till they fail, replace the front first.
