Wax on Hardtop
Old Sep 13, 2009 | 04:56 PM
Smiley88's Avatar
Default Wax on Hardtop
I have a father-In-Law (Girlfriends dad at least) who "helped" me out by waxing my hardtop...problem is that it is all turning white now!
It was done in July and it is all starting to powder up and turn white - what can be used to strip this without damaging the top itself.
Thanks-
Old Sep 13, 2009 | 05:35 PM
ben1284's Avatar
hmmm. dont know of a fix for that one..good luck with it though.
Old Sep 13, 2009 | 05:52 PM
mikesjk's Avatar
3M makes a wax remover that you should look into getting. I use it when I detail the bosses car on the trim and rubber, it works great
Old Sep 13, 2009 | 05:55 PM
JKRINGO's Avatar
Why would anyone wax the Hardtop? Only fix I can think of would be a light sanding and paint. Good luck.
Old Sep 13, 2009 | 05:57 PM
jmat1980's Avatar
Sand it and spray it with bedliner...ive beed dying to see one, so this is the perfect opportunity
Old Sep 13, 2009 | 07:13 PM
fadeout's Avatar
try washing the hardtop with Dawn, it cuts right through car wax down to the clear coat on the body, so it may work on the hard top. It can't harm it in any way either.
Old Sep 13, 2009 | 07:15 PM
09rubicon's Avatar
x2 also use a nylon brush on it with the Dawn, works great and the only cost is some elbow grease.
Old Sep 14, 2009 | 04:26 AM
Hitchhiker's Avatar
Try cleaning it off with mineral spirits.
Old Sep 14, 2009 | 04:39 AM
Goldorak's Avatar
a white staedler eraser and a lot of elbow grease will remove the white wax
then never re-wax it again
Old Sep 14, 2009 | 08:06 AM
mkjeep's Avatar
Once you get the wax off, just use 303 on it.
