Gear install kit or overhaul kit ?
Northridge has package deals on gears but I don't know which one to get the gears with the install kit or the overhaul kit ? I've got about 60,000 miles on my Jk 3:21 gears running 33" mt's. Also what spline count should I go with when I buy my axle shafts ? I'll be running the Jk Aussie up front and a detroit in the rear. I have an xmodel two door with the d30 and the 44 in the rear. Thanx guys. Any explaination about why you run the spline count you run would be helpful, I'm lost when it comes to this sorts thing.
with that many miles why wouldn't you want to replace the bearings. Get the rebuild kits and be done with it. I didn't know the aussie was available in different spline counts on the JK? Go for the highest spline count you can for more surface contact.
