Rough Country 2 1/2 " lift kit
After installing this lift kit which included new springs and shocks along JKS sway arm disconnects I feel a 'popping' or 'clunking' in the front end through the steering wheel. Any solutions? Yes steering was realigned after installation.
Tell those boneheads to replace the intermediate streering shaft and it will go away. There are also a couple threads about the grease in the boot mod that seems to cure it as well.
will they honor it in warranty post lift?
But if you browse through the hundreds of posts in the threads concerning the dreaded steering clunk, you'll see that it is due to a bad shaft, not caused by a lift or any other mods.
Browse here when you have a few hours:
https://www.jk-forum.com/forums/show...steering+clunk
Have them check the intermediate steering shaft. I had same problem and mine would clunk and was wondering too they found the shaft was worn. Had it to the dealer 4 times and never found it but took to another dealer and found it in 3 min. common issue. Needs to have grease fitting on it.
