Need advice on tire size vs. lift height
Old Sep 17, 2009 | 09:12 AM
greengiant's Avatar
Default Need advice on tire size vs. lift height
alright, ive been goin nuts tryin to figure out what lift i should get for my 08 2dr. i got 285 bighorns on the stocker 17s. the tires are gonna be on there awhile. when they wear out, ill get 33x12.50. I wont go any bigger than that. ive been lookin at teraflex 2.5 BB and spring lift and Rustys 2 & 3.25 spring lifts. what do you guys think would look and perform better? i dont want my shoes lookin like donuts...if you guys got pics you can post thatd be great! thanks inadvance fer the help!
Old Sep 17, 2009 | 11:54 AM
horwitzs's Avatar
What are your plans for use?
If you are mostly a daily driver, a 2" lift is plenty for 33's.
If you want to go off road a lot, you may want the little bit more lift to flex your suspension without rubbing.
Old Sep 17, 2009 | 01:30 PM
2climbbig's Avatar
I love rusty's 3.25 inch springs. They have much better articulation.
Old Sep 17, 2009 | 01:52 PM
only reason for a lift is to clear the tires. try to keep your center of gravity low jeeps are tippy enough as it is. i run 33" with no lift and am going to try 35" no lift with xenon fenders. do tires first then lift to suit. big tires and no lift is better than lift with small looking tires
Old Sep 17, 2009 | 02:56 PM
river2c's Avatar
The 33X12.50R17s will be similar in size to the 285 Bighorns you have on now. Maybe a tad taller depending on the brand. Do the tires rub now? A lift may not even be necessary but 2" should give you plenty of clearance.
Old Sep 17, 2009 | 10:36 PM
08leocon's Avatar
i have found this to be my best friend https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Old Sep 18, 2009 | 03:49 AM
greengiant's Avatar
They dont rub now, i just want more flex.
Old Sep 18, 2009 | 03:55 AM
greengiant's Avatar
Its my DD, but when the whistle blows, im in the woods with it. I really want to lift it, im just afraid it will look funny with my 285s. I have to wait till i wear my current tires out b4 i get the 33x12.50s .I havent been able to find any pictures of a two door with 285s and a lift.
Old Sep 18, 2009 | 03:58 AM
greengiant's Avatar
any body got pictures or a link to some?
Old Sep 18, 2009 | 04:06 AM
cgtweet's Avatar
Default re
Mine has the OME hd with 285/70/17's. I like that set up for daily drive and offroad, however I dont think the OME will give you the flex your looking for.
