Widen stock fender flares.
Old Sep 18, 2009 | 02:23 AM
Default Widen stock fender flares.
Hi.
Since i have 35" tires and 10" wide rims i have to get wider fenders(by law).
And since the exchange rate between usd and isk really sucks now i dont want to order some flares.
So my question is, if i cut my flares can i use fiberglass to fill the gap, i.e. will the fiberglass get stuck to the plastic in the orginal flares??
Regards from Iceland
Stefan
Old Sep 18, 2009 | 02:46 AM
bluerubicon08's Avatar
I'm not familiar with the laws in your neck of the woods, why do you need to widen the flares? Is it to have the whole tire covered? Or is it a side marker light requirement?
Here in Virginia the law is that you need to have side marker lights that show the width of the vehicle. You widen the stance with wider tires, you need to mark accodingly. A lot of people are using small marker lights on a metal tab that sticks out on the fender.
Old Sep 18, 2009 | 02:57 AM
The flare needs to cover the tread of the tire.
Old Sep 18, 2009 | 06:37 AM
Originally Posted by billi
Hi.
Stefan
fiber glass should work, just rough up the plastic
Old Sep 18, 2009 | 07:18 AM
RA070424's Avatar
Former Member
Sounds like a hell of a project. If all else fails, Xenon Wide flares are the way to go.
Old Sep 18, 2009 | 07:27 AM
mueller433's Avatar
You can make (or have them made) steel tube fenders (check out the Mountain Off-road Enterprises website).
Old Sep 18, 2009 | 09:44 AM
mistersir's Avatar
hehe when you said ISK i instantly thought of the currency used in Eve Online.
i had to google that to discover thats what the icelandic kronar is abbrv. to. lol.
Old Sep 18, 2009 | 11:16 AM
RubiRedRider's Avatar
You might look into rubber flare extensions. Looks like 40 to 50 USD$ for 1.75 or 3"
http://ww w.carparts.com/EASY-TO-TRIM-RUBBER-FENDER-EXTENSIONS-FLARES/GP_2008750_N_111+10718+600023018_10618.car
RB
Old Sep 18, 2009 | 12:40 PM
RB
Good idea, i have thought about using some sort of rubber, but i would like to have something more permanent.
eve online is icelandic
Old Sep 18, 2009 | 01:03 PM
Littlejon's Avatar
I know that Bestop has some stick on flare covers that come out about 1.5" wider than the stock flares for about half the price of the Bushwacker flares.
