Can your JK fit in the garage with a lift?
My garage has an 81" opening at the door trim. I'm looking at putting on a 4" lift with 35" tires. Does anyone have this configuration and can still make it into the garage? Any thoughts would be helpful before I spend the money.
Pics would be awesome.
Here is the same question from yesterday...
https://www.jk-forum.com/forums/modified-jk-tech-2/need-help-lift-tire-size-vs-garage-opening-101817/
One post in that thread:
4" lifts seem to be running around 5"-6" in 'actual' lift height. Then add another 1.5" for the new tires.
I have a 4" Teraflex lift with 37's and it fits just fine in my 7'-0" garage.
It looks like you might have some adjustment left in your garage door. You can normally adjust how high it raises, it doesn't appear from the pictures it is as far up as it could go. Just a thought..
