Proper way to tie down my JK!
Im moving to CO sunday and never had to haul a vehicle before but I have to since im doing it on my with a 26ft box truck
anywayz im putting her on a car hauler should I tie down off the D-rings or the frame wich is the safest way also can I use my winch up front
Absolutly do not tie a vehicle down by the frame!!
That is not the right way at all. Do you ever see a tow truck doing this? NO. Always tie down your axles and let you suspension work. Unless you are going to completely compress your suspension to the point where your vehicle cannot move do not tie down the frame or your straps and chains will come loose. And if by chance you were to wreck the vehicle probably will not stay on the trailer.
Always tie off the axles
yes just make sure break lines are out of the way. also make sure you go diagonally as in driver side axle to passenger side trailer so you make a X on the front and back
