For those running the Teraflex HD Trackbar..
Old Sep 28, 2009 | 08:14 PM
Hellbound13's Avatar
Default For those running the Teraflex HD Trackbar..
Can you tell me if when you move your steering wheel back and forth with the Jeep running if there is a lot of movement in the rubber bushings?
I don't mean the bolt moving, but on mine if you move the wheel back and forth with the Jeep running you can see the rubber bushing in the mounts flexing a lot..
Old Sep 28, 2009 | 08:29 PM
jkJason's Avatar
Hey your the one with the steering issues right? I'm still thinking about your other post. I have the tf forged tb and there is no movement. I know that their first gen. tb used different bushings, maybe that has something to do with it? Still though, I think if anything that would induce death wobble, not the symptoms that you described in your other post. But yea, there is little if no movement in my tb bushings.
Old Sep 28, 2009 | 08:32 PM
I am running the new trackbar. Have you layed under your Jeep with it on and moved the steering side to side while you watch the bushings?
Old Sep 28, 2009 | 08:41 PM
jkJason's Avatar
Yea i had an awesome episode with dw a few months back runnin the jks track bar and got very accustomed to watching my steering. The bushings on the tf bar have a slight amount of play but it's minimal at best. Sounds like you might have a lil' more. But didn't you say you but the stock bar back on and the problem remained?
Old Sep 28, 2009 | 08:43 PM
Yes that is correct but I just wanted to make sure that I am not having additional problems with the Teraflex before I put it back on.
Old Sep 28, 2009 | 08:47 PM
jkJason's Avatar
Ah gotchya
Old Sep 28, 2009 | 09:14 PM
wildandwillin's Avatar
I have it and have no movement while turning the wheel
