back spacing
Old Sep 29, 2009 | 06:31 AM
jkbluebeast's Avatar
Default back spacing
What is the correct back spacing for new wheels. I am looking at some American eagle racing wheels 15x8 5 on 5 bolt pattern and the back spacing is 3.25 will they fit. If not what is the minimum back spacing I need to look for.
Old Sep 29, 2009 | 06:33 AM
horwitzs's Avatar
That should be fine. Backspacing should be around 4.5" or less.
And that is only if you are installing wider tires than stock.
Check out the FAQs on the forum. They are full of basic upgrade info like this.
Old Sep 29, 2009 | 06:35 AM
ok thanks the tires I am going with are mickey thompson baja claws 33x12.5x15
