part numbers for rubicon transfer case planetary gears
Old Oct 5, 2009 | 05:56 AM
bigbluejk's Avatar
Default part numbers for rubicon transfer case planetary gears
Anyone know the part numbers for the rubicon Planetary gears? I know the dealer can blow apart the whole diagram and look it up... but they suck. They either will act like they cannot do it/ or order the wrong part. If anyone has these numbers I would appreciate it.
Old Oct 5, 2009 | 08:12 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Ouch. Did you get a hole in the t-case also?
Old Oct 5, 2009 | 08:18 AM
mkjeep's Avatar
Hmmm, sounds like someones' trying to modify the X tcase.
Old Oct 5, 2009 | 01:30 PM
ronjenx's Avatar
Go here h**p://www.berrysprinter.com/jeepparts.php
Pick out your Jeep from the drop-down and go to the transfer case pages.
I looked, but don't know exactly what you need.
Old Oct 5, 2009 | 04:07 PM
bigbluejk's Avatar
Luckily I didn't... Did you? That would suck so bad!
Thanks... Ill check it out.
Old Oct 6, 2009 | 08:50 AM
RCJeeper's Avatar
I've seen a picture of the 241 next to a 241 OR, and internally they are very different.
Carl Whitmore from Teraflex has the inside scoop on this since Teraflex makes the 2lo kit. According to him:
"They are both 241's, but that's where the similarities end. They use different shift rails, different shift forks, and different sectors. (the detent piece) They're completely different internally, the way they shift."
