Problem with the body lift
Old Oct 5, 2009 | 03:40 PM
Yoda's Avatar
Default Problem with the body lift
I started to install the body lift this afternoon. Model: Rough Country 1.25" body lift for Unlimited.
I have a problem.... and I need some tips
There are 12 body mount locations (6 on each side)
Each body mount location has 2 stud nuts and 1 center stud bolts
I have removed the 12 stud nuts and 6 center stud bolts of one side.
I lifted the body, BUT the frame is going up with the body!!! Did I forget something?
I lifted the body of about 3 inches. Is it enough?
I started with the passenger's side, it's maybe the problem?
I have untightened the nuts (a little bit) of the other side. Is it bad?
THe body is still "glued" to the frame
Old Oct 5, 2009 | 04:21 PM
CLOTAGAMES's Avatar
TRY THIS- http://project-jk.com/jeep-jk-write-...ation-write-up
Old Oct 6, 2009 | 05:18 AM
Yoda's Avatar
I tried again this morning
I drove the Jeep a few feet with no bolts on side side
Can't remove the body from the Frame...
Suggestions???
Old Oct 6, 2009 | 05:40 AM
wayoflife's Avatar
JK-Forum Founder
if you have all the (2) nuts up front and all bolts out for sure, are you sure you are lifting your jeep up high enough. as you lift, your coils will need to unload before anything comes up off the frame.
Old Oct 6, 2009 | 05:52 AM
Yoda's Avatar
You are probably right, I lifted the body only 4- 5 inches
I will go take another piece of wood, I will try 10-12 inches
Old Oct 6, 2009 | 06:47 AM
Yoda's Avatar
IT'S WORKING !!!
Thanks Eddie and Planman
It was a stupid detail...
Old Oct 6, 2009 | 06:49 AM
bigbluejk's Avatar
damn those pesky springs. Always pushing against stuff. mind bottling.
Old Oct 6, 2009 | 09:40 AM
Yoda's Avatar
One last question
I have installed the 5 big stud bolts of one side
And I realised that one of the stud bolt is 1/2 inch longer
I think its the rear one, but not sure?!?!?
Old Oct 6, 2009 | 01:35 PM
Yoda's Avatar
Originally Posted by planman
I think it is one of the back ones at the rear crossmember.
Where is the rear crossmember? Do you mean the last one of the rear of the frame?
Old Oct 6, 2009 | 01:54 PM
Yoda's Avatar
I found this in the Performance BL instructions
2008 only! Install kit bolt (12mm-1.75 x
140mm) all body mounts EXCEPT rear most
two. Install two kit bolt (14mm-2.0 x 140mm) in
two rear most body mounts. Use factory large
washer on each body mount.
Does it mean that the 2 rear kit bolts (one on each side) are longer?
"two rear most body mounts" I'm French and I don't understand this sentence...
