What backspacing is needed.. ??
Old Dec 4, 2006 | 05:48 AM
1BADJK's Avatar
Default What backspacing is needed.. ??
I just ordered my Mickey Thompson 33x13.5x16 Baja Claws and I want some plain black steel wheels.. What wheels and backspacing does anyone recomend.. ??? thanks Jay
Old Dec 4, 2006 | 05:58 AM
wayoflife's Avatar
JK-Forum Founder
CRAGAR Series 397 Soft 8 or 342 Black Wheels with 5" of back spacing will work. ProComp Series 97 will do the trick too
Old Dec 4, 2006 | 06:11 AM
1BADJK's Avatar
Is Crager a better choice over others like Pro Comp, Mickey, etc.. I've heard that some are very heavy compared to others.. Just want something that can handle some rock scraping...
Old Dec 4, 2006 | 06:14 AM
wayoflife's Avatar
JK-Forum Founder
Naw, they are pretty much all the same. I actually run Rock Crawler Tech 1 (ProComp) Series 97's on my TJ and Series 95's on my CJ. Both look great, function well on the trail and what can I say... they were dirt cheap (by comparison to alloy wheels of course )
Old Dec 4, 2006 | 10:28 AM
jeepinoutwest's Avatar
45mm is stock, however for a bit extra clearance i reduced miine to 25mm and my 285/70LT17s fit great without sticking out past the wheel well or no rubbing. You may want to consider even reducing that a bit further as your tires are two inches wider.
