View Poll Results: Did you install your AEV snorkel yourself?
I had someone else do it.
1
4.55%
I made the cut!!
21
95.45%
Voters: 22. You may not vote on this poll
AEV snorkel + stock hood
Just curious about how many people actually make the cut!
I'm trying to factor in prices of a few different upgrades and don't know if I should factor in $ for an install...
If you did pay to get it installed, how much?
PS: I've never cut any type of metal, let alone a 1yr old jeep's hood.
But seriously, i have a few friends who have made the cut and the snorkel comes with a metal piece of molding that fits right above the snorkel itself to hide any blemishes that may be on the hood and cover up for your mistake.
It's not a big deal, buy a 4.5" grinder/cutting wheel and a good dremel, then "Katy bar the door" because once your comfortable cutting and grinding on your Jeep amazing things will happen, like your wallet will be heavier.
Just use some common scense.
) and sand stuff down a few times. Is it possible to use the dremel for the whole cut? or would that take WAYYY too long?
A good hole saw and a die grinder, 10 mins and it is done.
I took clear spray paint and painted the cut to keep it from rusting, I also plan to put some plastic edging on the cut so that when to hood is up you don't see the raw edge.
I guess i could have used body colored paint and not had that problem, anyway.
Do it yourself, that is one of the things that make Jeeping so fun, learning how to modify and fix all the things that break.
I guess i could have used body colored paint and not had that problem, anyway. Do it yourself, that is one of the things that make Jeeping so fun, learning how to modify and fix all the things that break.
