PRESS RELEASE: Die-Tech Off-Road Seat Mounted Fire Extinguisher
Old Oct 7, 2009 | 01:05 PM
wayoflife's Avatar
JK-Forum Founder
Arrow PRESS RELEASE: Die-Tech Off-Road Seat Mounted Fire Extinguisher
Fire extinguishers are valuable off-road and most off-road parks and recreation areas require that you have one. However, it’s a good idea to have one even when not required, because a fire can start for many different reasons.
We’ve taken a high quality fire extinguisher and built a bracket so that it can be mounted to the seat where it’s most accessible without being in the way. Our bracket mounts to the driver’s seat frame and is a complete bolt-on solution that takes only a minute to install. No drilling is required.
Seconds matter when a fire is concerned. Don’t sacrifice your safety with a fire extinguisher that is out of your reach.
The included 2.5 lb. ABC fire extinguisher is rechargeable. Our brackets are made in the USA.
For more information regarding Die-Tech Off-road and the products that they make, please visit their website at: www.dietechoffroad.com
Old Oct 7, 2009 | 01:07 PM
wildandwillin's Avatar
I just put a fire out last sat on a buddies rig. I need a replacement.
Old Oct 7, 2009 | 01:08 PM
BlackNorthernJK's Avatar
bumpity bump for ya...just started looking for a new place to mount mine...search over
Old Oct 7, 2009 | 03:05 PM
FlameRed's Avatar
Ordered this kit moments ago. After seeing that fire this weekend, it shocked me into the realization that I've been pressing my luck not having an extingiuser with me.
Old Oct 7, 2009 | 04:05 PM
kflash's Avatar
Where do you get a fire extinguisher "recharged"?
Old Oct 7, 2009 | 04:11 PM
JPop's Avatar
I bring mine into work when we have the fire extinguisher guy come once a year to re-certify all our fire extinguishers. There are also plenty of places in the phone book for carry in service. A bigger question is are the ones you own designed to be rechargeable.
Old Oct 7, 2009 | 04:16 PM
8000ft's Avatar
I've had mine there sense the first week of ownership, I had an engine fire is a past car and with out the on board fire extinguisher it would have been a total loss.Click image for larger version
Old Oct 8, 2009 | 06:04 AM
tgrt's Avatar
Former Vendor
There are specific fire extinguisher companies that obviously vary based on where you live. You can go to your fire department and ask them for recommendations. And maybe you'll get lucky, in a previous place I lived the fire department actually did the recharging.
Old Oct 8, 2009 | 06:08 AM
tgrt's Avatar
Former Vendor
I was shocked into realization last year when I had to put the fire extinguisher to use. I was running I guess what you'd call a prototype to this kit at the time. We were on a trail and spotted a fire under the engine on a TJ. I was able to grab the extinguisher and have the fire out before the driver of the TJ could get his fire extinguisher (I don't remember for sure, but I think he had a rollbar mount).
It turns out the fire was caused when a cable pulled loose on the power steering. The fluid caught fire on the hot engine. Luckily I got the fire out before it did anything other than cosmetic damage.
Old Oct 8, 2009 | 06:13 AM
AZOverland's Avatar
I like this idea. I have my Streamlight flashlight mounted under the drivers seat. Will this kit work on the passenger side as well?
