Teraflex Disco Brackets/Pins with Stock Links
Old Oct 7, 2009 | 09:23 PM
bluesurf09's Avatar
Default Teraflex Disco Brackets/Pins with Stock Links
I was just wondering if anybody knew if I could buy the Teraflex Quick Discos Frame End Bracket Kit and two Teraflex Quick Discos Pin Kits and use that with my stock links?
I know that I could just buy the Teraflex discos and be done with it but I am probably going to be getting the leveling kit too. But at the same time I don't know when I am going to get the leveling kit and kinda want discos that would work with the stock links and thought this might be a cheap solution.
Old Oct 7, 2009 | 09:30 PM
wildandwillin's Avatar
The discos will work with the stcok and leveling sysytem. As far as wroking with the stockers. why? its a small investment. But yes you can use them like regular discos.
Old Oct 7, 2009 | 09:35 PM
bluesurf09's Avatar
I understand the discos will work with stock system. I would rather use the stock links combined with the Teraflex parts on the stock setup until I got the leveling kit.
Also I guess the biggest concern I have is the inside diameters or the stock vs Teraflex links. Are they different? I don't want there to be any play.
Old Oct 8, 2009 | 08:02 AM
bluesurf09's Avatar
FYI the part numbers I am referring to are #1601277 and #1943705. Thanks.
Old Oct 8, 2009 | 05:58 PM
bluesurf09's Avatar
Nobody? Teraflex Joe can you help me?
Old Oct 9, 2009 | 05:37 PM
bluesurf09's Avatar
PM sent to Teraflex.
Old Oct 9, 2009 | 06:46 PM
YellowToy's Avatar
wont work, diam. of the tf pin is too large
Old Oct 11, 2009 | 05:23 PM
bluesurf09's Avatar
Figures they had to go ahead and make their stuff beefier! Nah just kidding that is great to hear even though it won't help me now. Good to know the quality is there when I do buy their stuff.
Old Oct 11, 2009 | 06:34 PM
jeepnxj3's Avatar
What if u press out the inner metal sleeve and use it with just the rubber bushing?
Old Oct 11, 2009 | 06:39 PM
bigbluejk's Avatar
what if you just spend $100 and just buy the tera ones you know will work the way you want?
