2.5 spacers with 4 inch lift???
A guy at work said it was possible to do this. ( they said they did it on his buddies JK). He said i could install 2.5 TF spacers on top of my 4 inch skyjacker suspension. I dont think it could be done without super mods to the drivetrains and such.. I figured i get the opinions of the JK community if it was even possible or if anyone has even seen this before???
Browse this one...
Adding two inch spacers to 4" Skyjacker lift
https://www.jk-forum.com/forums/modified-jk-tech-2/adding-two-inch-spacers-4-skyjacker-lift-104407/
But, 'which' particular skyjacker kit do you have? Guessing the budget one? In which case you'll want some way to adjust caster front and back. (so at least two sets of adjustable control arms) New driveshafts. Longer shocks. Longer brakelines/brackets. More bumpstop. Longer links. New adjustable trackbars instead of brackets.
My guess is that you would be better off selling this one and just buying a complete 6" kit
JK401KCR ?
No cams, and a single set of fixed arms front and back sound right?
All of the components are fixed, and used in all of their 2-4" lifts. (so my guess is that they are already on the short side...) You will need to add most, if not all, of the components above to bring you back to your current ride quality.
