R.C. Disco's w/Teraflex L.K.?
Hey Guys, I'm really interested in the R.C. disco's, great price! However, I'm not sure if they will work. I know that the specs on the disco's call for a 2.5-6" lift. I have the tereflex leveling kit which raises the front 2" and rear 1". Is anybody running this setup? Do you think this will work? Can't I just thread the rods some more and cut some of it off to make it work? Thanks for the info.
Because they are most likely better quality and easier to install for sure....with the TF, no drilling into the frame to mount the bracket that stows the link when disconnected...with RC, you gotta drill holes to mount that bracket.
Plus, as stated above, you can get the TF in the size you need which is 0"-3" of lift...perfect.
oh and to answer your question it should work with any modifications to the actual discos...i put discos for a 4-6" lift on my jeep an i only have 3.5 inch lift. it didnt affect anything other than the handling (but in a good way) the longer discos let me turn corners better because my stock ones were like 4" long and were not letting the body roll at all in turns. so if you about 2" in the front and adjusted those discos all the way down it should be fine
I suppose, I don't remember what exactly my stock links were like....someone else might know. I understand the money thing, trust me...but if I were you, I'd wait until you're able to get the actual stuff necessary to make it work right....but that's just me.
The sway bar links I have on now are Teraflex, they came with the leveling kit. They just aren't quick disconnects. It looks as though all I would have to do is buy the quick disconnect hardware to make them so. But they do not specify that on their website.
OK, so the leveling kit came with new front links? I thought it came with new rear links and then you move the rear to the front....oh well, disregard what I said then..lol.
