Question for fitting 15" wheels on Sahara
Old Oct 11, 2009 | 07:27 PM
maddygirl's Avatar
Default Question for fitting 15" wheels on Sahara
What modification if any, is necessary to fit a 15 inch rim on a 2009 Sahara?
Old Oct 11, 2009 | 07:29 PM
JKBully's Avatar
at most you may have to do a little dremelling on the brake caliper. I think that really only applies to steelies though. I haven't heard of any probs with the alloys!
Old Oct 11, 2009 | 07:30 PM
Mulewhisperer's Avatar
What tire size are you going with?
I have 15's Pro Comps. The only thing you have to do is watch where they put the balancing weights. When I got my tires and wheels I was excited and didnt pay attention. I put them on and backed out of the driveway to see that my brake calipers stripped all of the weights and left them in my driveway.
Edit: My rims fit without trimming, it was the weights that were touching
Old Oct 11, 2009 | 07:46 PM
nthinuf's Avatar
Browse this one, if you haven't already.
https://www.jk-forum.com/forums/modified-jk-tech-2/15-wheels-what-fits-what-rubs-find-out-here-94709/
There is also a 15" wheel section in the faq with a little more info, but this link is better.
Old Oct 12, 2009 | 06:11 AM
2climbbig's Avatar
I have the Unique 15in steelies and they work just fine.
Old Oct 12, 2009 | 01:13 PM
bradj1964's Avatar
I have american racing outlaw 2 15x8 3.75 backspacing on my 08 x model no problems here, I made sure they put the wheel weights on the inside wheel lip, and not the stick on kind that go on the inside of the wheel, I heard the wheel weights might possibly hit on the brake caliper, like the other guys post said his hit his calipers just to be safe!!
Old Oct 12, 2009 | 02:46 PM
BBirish's Avatar
i have the cragar soft 8's in 15x8 and they fit fine. if one doest fit try another wheel in that spot, they are not all the same - had to do this with mine
Old Oct 12, 2009 | 02:54 PM
Suffolk JK's Avatar
15x8 Cragar V5 in 3.75" BS. Needed to grind the caliper "forward" bracket a little (the bracket closer to the hub). No rim fit. Had to shave a 16th, TOPS. Works wonderful.
