Tight Trackbar
Old Oct 12, 2009 | 02:22 PM
aBē's Avatar
Default Tight Trackbar
I installed a JKS Adj. Trackbar (front) but didn't use a torque wrench... can a tight trackbar can cause DW? what about the other suspension components??
Old Oct 12, 2009 | 02:42 PM
wayoflife's Avatar
JK-Forum Founder
if you didn't use a torque wrench, you most likely didn't tighten the bolts enough. 125-130 ft lbs is a lot of force and there is no way you can get that with a standard wrench.
Old Oct 12, 2009 | 02:45 PM
aBē's Avatar
So this can cause a DW... There should be some moderator who speaks or understand spanish so anyone else (like me) who is not from USA can explain propertly what the problem and the symptoms are
Old Oct 12, 2009 | 03:20 PM
JKRockStomper's Avatar
This can cause DW. Torque that trackbar down.
Old Oct 12, 2009 | 03:41 PM
aBē's Avatar
So you mean start over?
