rockhard evap skid - install help
If you have the rockhard evap skid... and have SUCCESSFULLY installed it with ALL 3 bolts please tell me how!
Basically the skid appears to be a bit longer than the bolt spacing, and I cant get the rear single bolt in.. only the front 2... and i have tried barely threading those to allow for some play...still no go.
I have a ziptie holding on the rear right now
Thx in advance!
Thx in advance!
well i took another crack at it... used my floor jack to force the skid up / flush with the rear beam.
it aligned almost perfectly..except for about 1/2millimeter too long. the bolt still wouldnt catch a thread and go in.. so i think ill take everyones advice and just drill the hole a bit this weekend.
Thx!
Thx!
Have you tried putting the rear one in first, then trying the front 2? Might be easier to do it that way, if the front two don't line up, then that skid was drilled wrong or something. Those holes should line up evenly with the evap holes. Mine went right in. You shouldn't have to force anything.
Like flamered has said just elongate the holes.
