She's listing starboard
After installing a TeraFlex rear axle adjustable trackbar mount on Friday I found my JK is riding higher on the drivers side. Measuring after the install the drivers side was 1/2 inch higher. I have the track bar in the upper most position on the bracket and the axle is centered on the vehicle. Half way down the trail on Sunday and after flex to the bumpstops I parked the vehicle on level ground and the passenger side front was about 2-3 inches lower then the drivers side. Way the list?
After eyeing the axle postion on the lift I put it in the upper most hole on the bracket. The distance from stock to the upper hole was about the same as the distance on the drop bracket it replaced and axle is centered. Seems like there is some problem with a "bind" of the front and rear track bars. I don't have any kind of high steer kit and am wondering if there is some abnormal suspension bind happening now. After driving back home the jeep is leaning about 3/4 inch.
Great track bar bracket TeraFlex, really flex the jeep out like never before yesterday and not contact in the rear.
