Pro Comp 8069's and 35" Mud Terrains Installed
Old Oct 26, 2009 | 06:47 PM
Schantin's Avatar
Default Pro Comp 8069's and 35" Mud Terrains Installed
Finally got around to taking pics. Overall am quite pleased with this setup. Tires are pretty quiet for mud terrains and no balance issues.
Running 16" Pro Comp 8069's with Pro Comp 315/70 R16 Mud Terrain tires. I put one on the scale out of curiosity..... 86.4lbs per wheel/tire. I'd hate to see how much steel rims would have weighed!
Lift is an OME 2" with HD springs and JKS trackbars/Currie endlinks from Northridge. Only rubbing is on the plastic swaybar disonnect cover under the front bumper. A little cutting and that prob will be solved I also got the wrong bolt-pattern for the spare (they sent me a 4 1/2 bolt pattern by accident), but just received the correct one tonight.
Anyhow, here's some pics:
Old Oct 26, 2009 | 07:04 PM
Schantin's Avatar
Originally Posted by Geeper4x4
picture of stock green rubi?
Check the post again..... it took a few minutes for the pics to load
Old Oct 26, 2009 | 07:20 PM
You Jeep's Avatar
Good looking rig, it's nice to have bigger tires huh!
Old Oct 26, 2009 | 08:09 PM
bigbluejk's Avatar
Those look great! What is the load rating on those tires?
Old Oct 26, 2009 | 11:26 PM
aldaman's Avatar
Originally Posted by Schantin
Finally got around to taking pics. Overall am quite pleased with this setup. Tires are pretty quiet for mud terrains and no balance issues. Running 16" Pro Comp 8069's with Pro Comp 315/70 R16 Mud Terrain tires. I put one on the scale out of curiosity.....
Nice ...Do you have pics of the front & rear profile that you can post...I have the same rims and looking to upgrade to 35s...Thanks...
BTW..I painted my center caps black using the krylon fusion paint...Now just need to look for black lug nuts...
Old Oct 27, 2009 | 04:18 AM
joneszj's Avatar
Going for this look? Got the lugs from quadratec...the pro comp allot lugs...
Old Oct 27, 2009 | 04:35 AM
Schantin's Avatar
Thanks for all the comments.....and yes, having bigger tires has been very nice so far
Old Mar 23, 2010 | 05:21 PM
Bxjk's Avatar
Default pro comp's
are you using tpms???
and was this a package that you bought if so
where did you get these awesome wheels
thanks
Old Mar 23, 2010 | 06:53 PM
dsmSpidey's Avatar
Looks great!
Old Mar 23, 2010 | 07:02 PM
racin444's Avatar
Man that set up looks good. I love the Pro Comp 8069s!
Cant wait to get a set and wrap em in 37s
