Anyone break anything after HEMI swap yet?
That sucks
looks like that is a rear axle out of a buggy or non JK judging buy the truss and rusty hard brake line going over the pumpkin
If that is a rear looks like it may be time to swap to a low pinion 60 or 80 or possible change gear brands and ratio
If that is a front axle in a JK witch it looks like it may be because of the truss but the brake line makes no sense
Tell the owner he is the man and drives like an animal ,Dana 80 would be your option or you could try a different brand gear
I broke 2 passenger factory front axle shafts, then upgraded shafts an knock on wood, haven't broken anything yet.
Eventually would like to upgrade to either the 609 or 60 but hopefully the 44s will last a couple years before I do that.
Thats the rear in our Hemi TJ. After 3 sets, I'm a firm believer in low pinion rears now. Of course, if I knew how to drive, there'd be no breakage. Adam
