Who has these sliders???
I am looking for pics and/or detailed descriptions of the undersides of the sliders manf'd by PureJeep and Rock Hard. Specifically, I'm interested in the method used to mount the sliders at their bottom surfaces.
Additionally, I would like to know how well the Rock Hard slider fits to the rocker panel below the door openings. Does it follow the body curve nicely?
And....How hard was the installation... if difficult, then how so?
Thanks in advance for your help!
The install on the PureJeep rockers were a bit harder than I had anticipated. But it was well worth it. The PureJeep sliders mount to the under side at a few different points and bolt into the pinch seam, but the body mounts seem to be where the brunt of the bolts are. There's 3 bolts you drill into underneath the doors, then the 4 you can see on the upper parts of the sliders. The PureJeep rockers are the best. They look sweet, and there is no way I am getting rocker damage any time soon. I'll see if I can get a few pics for you later today.
Check this out -->https://www.jk-forum.com/forums/show...liders+install
Even after the hassles, it was well worth it.
