Alpha Ex helped me get the big one in...
Yep, thanks to Dave at Alpha Expedition I was able to get my large Viair compresor under the hood. Looks stock sitting in there. I nice fit with a simple install.
Token poser pic...
THANKS DAVID!
Click me to learn more about Alpha Expedition and how they keep you prepared!
Token poser pic...
THANKS DAVID!
nice, do you not worry about it getting wet or anything like that? or does it not matter? I have a viair compressor right now but i dont know if i'd feel comfortable mounting it under the mood cause of all the water/mud that gets under there.....
Because of the bracket and the location I do not see it being any kind of problem. However, I am sure there is a way. But, I have had a compressor mounted under the bed of my truck for 4 years now without a problem.
so the mud and water should not effect the compressor at all?
also what did you do with the wire clamps at the end? just wrap them up somewhere and connect to battery when you need to use it? i can't tell from the pics. thanks,
I wired the compressor to the battery. I cut off the clamps and ran the wires across the fire wall.
