aev 4.5 prem is on!
before
6dof burning steel!
more pics to follow its only been a few hours between us finishing and me going to work. its hard not to want to up grade to 37's now
maybe itll settle an inch
btw no cam bolts tereflex lca's and they are beefy
much thanks to 6dof, and 2k2wranglerx for the drill bit run
6dof burning steel!
... that pictar makes me look fat ...
FAKK i'm sore today! left work early yesterday, rolled him in and got to work about 2:45pm ... he rolled out and left at about 1:45am. there was dinner breaks and a run to PepBoys in there too. and the last 1-2 hours was SLOW progress as we kept lyin on the floor wanting to sleep
great lift, great parts ... but the C2 gussets i welded in were ALL in the way of the AEV axle brackets. those brackets were chopped up to fit (should have seen nick cringe
) and then welded in place. they fit tight and are now bolted to the old brackets and then welded to the axle, vs. some alignment tabs and a u-bolt. that chit aint going NOWHERE, but this took up a LOT of time. and after welding the C2's in very slowly with lots fo brakes to keep the balljoints i didn't remove cool ... was time i'd have rather spent re-installing the axle.
the run to pepboys was for nuts ... one of the bolt kits had 1/2-20 bolts and 1/2-13 nuts
Nick, you should also get a pic of how we re-located your e-brake cables. after what the dirrections said to do, a lot of ppl might like this better.
now if you'll excuse me ... i'm going to fall asleep on my desk ...
) and then welded in place. they fit tight and are now bolted to the old brackets and then welded to the axle, vs. some alignment tabs and a u-bolt. that chit aint going NOWHERE, but this took up a LOT of time. and after welding the C2's in very slowly with lots fo brakes to keep the balljoints i didn't remove cool ... was time i'd have rather spent re-installing the axle.the run to pepboys was for nuts ... one of the bolt kits had 1/2-20 bolts and 1/2-13 nuts
good job man..... I love the AEV lift. how do you like the ride compared to what you had??
mine is a dream. Im actually taking it on an 8 hour drive tomorrow and am looking forward to driving over the NASTY roads in Brooklyn NY
thats why i went aev, i put like 25,000 on my jeep and its like a year this week so i wanted something super road friendly. downfall to the 4.5 is it desires 37's so i guess ill need to do gears some time soon
